Flightplan not working
Lestat
Hi all I have not Flown the anafi in quite some site yesterday anScreenshot_20230504_182502_FreeFlight 6.jpgd today I tried to do a flight plan all looks good to me but when I press the play button the anafi dose nothing
All attempts the anafi has been in the air as the field I am in is not even
On my phone the play button goes gray for a second then back to normal
The anafi just stays hovering and dose not move at all
Screenshot_20230504_182449_FreeFlight 6.jpgScreenshot_20230504_182340_FreeFlight 6.jpg
Have I done so thing wrong
Try creating a new flight plan without any camera tilts in first couple slots of timeline
Btw. Also confirm you have a gps lock
Reactions: Lestat
Just wanted to say thank you I re did the flight plan and did not add any angle changes and it worked perfect
Reactions: BRC
I am on v6,7,6 I had not tride using flight planing in over a year it dose seam to be a bug with the angle change in the flight plan the the flight plan would not start
With out the angle change it worked with out a problem
I did not get a chance to try the ange change in different parts of my flight
i have not reported it to parrot was on holiday at the time of my first post
and have not had much time to try and reproduce the problem
While not directly related to the above problems experienced with FF6 and Flight Plan, below might help some...
While not Connected to an Anafi, I could not get to the screen on my iPad that enables changing the Piloting Mode to 'Flight Plan'.
I Removed FF6 from my iPad, then I went to the App Store and re-downloaded FF6.
After opening FF6 to the home screen, I tapped to restore Purchases, and tapped RESTORE PURCHASE to restore Flight Plan.
Now... I tapped on "Try" in the lower right (later would typically be "Fly") and the main flight control screen was displayed.
Now I could tap on Piloting Mode and scroll left on the lower bar to select 'Flight Plan'.
At this point I am hoping that FF6 and Flight Plan are still functioning.
(No login to an account on Parrot.com was required.)
