Forgot WiFi password and tried Factory Reset to no avail
Hi all,
Maybe someone has seen this before? I tried both the "2 presses of switching on with a third long press" and also the "4 presses of switching on and holding for 10 seconds". Neither worked and now my C.H.U.C.K is displaying the follwing when switched on with one press:
2 short blue flashes
White light and then a beep
Motors controlling the flaps buzz
Green solid light
Still no WiFi, Skycontroller cannot connect.
Is this C.H.U.C.K bricked?
I have two of these Discos and very not wanting to try to Factory Reset the other Disco.
Any help would be massively appreciated.
I already also have a mini USB with the PLF file from Parrot V 1.3 that it shipped with.
I can't believe they'd make this insanely difficult to just set the C.H.U.C.K back to original shipped settings. I've been hunting around quite some days already and for the light sequence I'm seeing and can't find anything.
Have a good week people!
BR,
Possibly Infected.
Hi all,
Green solid light
BR,
Possibly Infected.
Hmmm ... what are you trying to achieve by: "2 presses of switching on with a third long press" and also the "4 presses of switching on and holding for 10 seconds"? What is that supposed to do?
Sry I was blind, so you are trying to reset Wifi pwd e.g. set a new one - okay makes sense ... I have to check the docs what Parrot recommends in that case. One last resort could be to telnet into your drone and check the current credentials or alternatively overwrite with new values.
sanjay07
