Freeflight 6 mod app
FF6_6.7.0_212_FCC_Selectable.apk
I have Sync Problem-Internet Connection error on start-up...
Cannot do that since there is no FF6 in Google Play anymore...
What shall I do?
Screenshot
Free flight 6 is still there in Google play
Ok, solution:
- downgrade tablet to Android 10 (or buy a cheap one)
- install beta FF from Google Play
- save obb folder
- install modded FF6 👍
I am not clear on your question but if you are looking for a modded app for latest version of FF6 for Android app I have put link below look at post #1. Make sure you search through other users posts in regards on how to install and saving existing OBB file by renaming it and then adding back in with original name as necessary. I have never needed to do this but others have run into sync issues if not done properly. Btw make sure to select correct file off his sever as there a few different version to select from.
Good luck
hello and thank you, I followed this method but the application closes every time. I have tried the installation method several times but the application always closes.
ibrah99
