FVP Focus problem
Northponder
Hi all, Northponder here living in the mountains of western Maine. I can't get a clear picture when I put on the goggles. It doesn't seem to matter if I have my glasses on or of or reading glasses. I get a blurred picture. I could use some help with that. Also is there better-set google that are compatible with the Bebop 2 Power?
Are you using parrot cockpit glasses,is it cockpitglasses 1(white and black plastic) or cockpitglasses 2(black,rubber)?
If the headset is anything like tat of the Anafi FPV headset, there is a switch that brings the lenses closer and farther apart, and I also discovered that it can be blurry if your phone is in there at even a slight angle.
Try rotating your phone a smidge when it is clamped into the headset, or open it and rotate the phone by a degree or so.
Thanks, I'll give that a shot.
