Need new motor bebop 2 power front right
Roywoolvin
After new motor top of motor moving none of the others do and it won't work all the rest do don't under stand what has happened to it are they easy to change
It's possible that the new motor you installed is not compatible with the other motors or is not properly installed, which is causing the other motors to not function properly. Here are some steps you can take to troubleshoot and potentially resolve the issue:
  1. Check that the motor is properly installed and securely connected. Make sure that the motor wires are properly soldered or connected to the drone's circuit board.
  2. Verify that the new motor is compatible with the drone. Check that the new motor has the same specifications (voltage, current, and RPM) as the other motors.
  3. Check that the motor is spinning in the correct direction. If the motor is spinning in the opposite direction, it can cause the drone to become unstable or not fly properly.
  4. Calibrate the drone's gyroscope and accelerometer. These sensors can sometimes become misaligned during a crash or motor replacement, causing the drone to not fly properly.
  5. Try swapping the new motor with one of the other working motors. If the new motor works in a different position, then the issue may be with the drone's circuitry and not the motor itself.
As for changing motors, it can depend on the type of drone you have and the level of experience you have with electronics and soldering. In general, replacing a motor can be a fairly straightforward process, but it does require some basic knowledge of soldering and electronics. If you are not comfortable doing it yourself, it may be best to take your drone to a professional or contact the manufacturer's customer support for assistance.
