Rolling spider spins automatically and out of control when paired with a block coding program. I'm using SamLabs application.
AHIL
Works perfectly with freeflight mini, but spins automatically when paired with a block coding program. I'm using SamLabs application.
The drone spins out of control. Have to manually disable connection from the block coding application. I updated the firmware twice.
I have tested other rolling spiders with this app and issue does not occur so the issue is isolated with this drone. Any thoughts on what could be the issue?
Thank you.
