3rd Anafi Thermal - 3rd problem
BryceSteiner
Got another Anafi Thermal to replace the 2nd one that replaced the first one. So far, the first one was the best.
1st - constant recording problems with the SD card slot. Even after changing cards or putting the original in.
2nd - Can't fly - Drone has an error.
3rd - Came today. I power it up and update the firmware on everything. it looked good. Then I went to calibrate the horizon in the camera and it shook:
I thought maybe it was just a glitch in the app. I took it up after finishing all of the calibrations. it still shook in all the videos.
I've reset the drone and it made no difference. I've run the gimbal calibration about 5 times and makes no difference. About half the time it does not complete the calibration which may indicate another problem.
It will also be glitching in the video like a bad TV reception.
One thing too about the camera is after about 5 minutes of the drone being turned on the camera gets VERY warm, if not hot.
Is there something I can do about it or is this just not the drone for me?
Maxence dlh
