4K videos lenght. More than 5 minutes?
Sportback
Hi, I was wondering if there is a way to make long 4K videos. The maximum lenght of them is around 5 minutes and don’t know if is it possible to make them of the same lenght than the flight.
Thanks in advance!
He's likely talking of the split files. They are "long recordings" once you collate them in your favorite editing software or use an utility to join them. Almost every camera out there splits files at <4GB as that's the max the mp4 container can officially hold, and also the max filesize limitation for FAT32-formatted cards.
Reactions: Sportback
Ok, thanks for the answer and the explanation!
Dashware has a file merge option which will make a lossless file of complete flight.
Fast process.
Dardo
