Anafi Cameraman
pmh1nic
I had my first opportunity to use the cameraman feature on the Anafi trying to capture boat footage. It took me a little while to figure out the best way to get set-up to capture the boats coming into the bay but once that was done cameraman makes it very easy to keep things framed correctly while you only have to be concerned with flying.
I have found it works well when the object you want to film stands out against its background, doesn't blend it. Also, distance is your friend. Too close and it can get tricky on staying on target.
BingoSoft
