Did you check this location's cable connection securely? Did you try to unplug and re-plug this flexible cable?
Yes I tried to re-plug the flexible cable .... nothingDid you check this location's cable connection securely? Did you try to unplug and re-plug this flexible cable?
How about the cooling fan and bottom's power indicator's behaviour after you pressed the button on battery?Yes I tried to re-plug the flexible cable .... nothing
neither the fan nor the led below turns onHow about the cooling fan and bottom's power indicator's behaviour after you pressed the button on battery?
