Anafi FPV
DonH
McNeal, AZ 85617
Any suggestions of a set of VR goggles for my new Anafi? According to Parrot-
"Cockpitglasses 3 are not available at the moment, please try to check it on eBay."
Anything else out there that matches up well?
https://www.amazon.com/Spectre-Folding-Virtual-Reality-Accessory/dp/B01N1QZD60
These Spectre VR goggles are basically identical to the Cockpitglasses 2. (The only difference from Cockpitglasses 3 is one button instead of two.)
Select Cockpitglasses 2 in the FreeFlight6 > Interface settings and they will work fine.
I bought the same model. I had a problem with the goggle not latching securely but at the price it wasn't worth returning so I came up with an easy fix. I inserted a folded piece of cardboard from cereal box between the foam and the frame near the latch hole and it worked fine after that. The cardboard pushed the frame out enough to properly catch the latch.
The responders above have it right! Anafi recently included their FPV mode. Use "Cockpit Glasses 2" and the "second button" is controlled in the software by the joysticks. Great solution on Parrot's part.
Reactions: DaveN
ladieslovexme.
