Anafi leg not touching surface
MightFlight
One of the feet on my anafi FPV are not fully touching the surface when placed on a flat even surface. It is floating. Anyone with this problem, do yours touch? What could be wrong?
Maybe its a defect. When the drone is closed all touch when open only 3 touch. Maybe the plastic spacer ring is in wrong? No motor wires look caught at the hinge.
Maybe it’s a defect. When the drone is closed all touch when open only 3 touch. Maybe the plastic spacer ring is in wrong? No motor wires look caught at the hinge.
That’s odd. Could be the spacer washer it goes in between the two legs. Also I’m assuming you have the rubber foot on leg and the rubber piece that attaches to bottom of body below where battery attaches. Best of luck.
cloud9rc
