Anafi transmission parameters - Equipment type Approval requirement
sibujacob
Kuwait
Hi
Can anyone provide the answers for the following details about the Parrot Anafi
Section- B- Details of Transmitter
  1. Frequency range :
  2. No. of preset switchable channels :
  3. No. of voice /Data/ TV Channels :
    ( In case of multi- channel equipment)
  4. Tx-Rx channel separation :
    ( In case of Duplex/multi-channel equipment)
  5. Adjacent channel separation :
    ( In case of multi-channel equipment)
  6. Frequency stability :
  7. Spurious/ Harmonic radiations :
    i. Carrier suppression :
    ( In case of carrier suppressed systems)
    ii. Unwanted side band suppression :
    ( In case of SSB systems)
    iii. 2nd Harmonic radiations :
    iv. 3rd Harmonic radiations :
  8. Max. Frequency Deviation :
  9. Mode of emission :
  10. Bandwidth of emission :
  11. Test Tone deviation :
  12. Base band frequency :
    ( In case of multi channel equipment)
  13. Type of modulation to be required :
  14. Pre-emphasis :
  15. Power output :
    ( At the input of antenna)
  16. Any other information :
Section-C- Details of Receivers
  2. Mode of reception :
  3. Spurious response of receiver :
  4. Sensitivity :
  5. Frequency stability :
  6. (a) Effective noise temperature :
    (b) Threshold input level :
  7. Intermediate frequency :
  8. De-emphasis :
  9. Selectivity :
It uses WIFI - and type approved for use as an WIFI device, so whatever the WIFI licensing terms are in your country you can use them specs for the information you need above.
Reactions: sibujacob
is there a sample page which you can share here
Oh wow really. Thats to bad. I tried to find a FCC ID sheet just for the SC3 but I could not find one. I'm sure there must be one out there but its like jumping down a rabbit hole. After a while I was just going around in circles with no real info.
Sorry
Sorry
Hi, you must use the product development code "MPP3" instead of SKC3 for trying again may be in successfully. Good Luck!
Sorry
Actually what i did was read the FCC Id on my SC3 and then search the file on the FCC site. I found it. !! It is present ...
Similar threads
