I would use this but you have to be carefull not to put any pressure on button...i have small crack right above button ,due crack there was pressure on button causing bebop to start the moment battery was installed....i was able to reinstall button,release pressure from crack and get it to work...make sure piece is not pressed to deep when you glue it ?(dont glue it around white button or remove white button before glueing it)
