Bebop 2 RTH not working, and fast landing
BarbarosTUGRUL
hi guys,
i have a bebop 2
using flight pro app
i push Rth buton then drone is turn to rth, but not come to home?
there is any problem?
also bebop2 take off fast landing
thank you everybody
@user guide
You can take control over the Parrot Bebop 2 when it is returning to its starting point.
If the Parrot Bebop 2 altitude is below 20 meters, it will rise to an altitude of 20 meters
before returning to its starting point.
This decreases the chance of colliding into
obstacles.
If the connection between your smartphone and the Parrot Bebop 2 is lost, the Parrot
Bebop 2 returns to its starting point automatically after a certain period of time. To set
this period of time. Within the FreeFlight Pro application, go to Settings > RTH and set
the desired period of time."
my drone is not altitude 20 meters, landing 2 meters and waiting not rth :(
Hi....make sure there is distance between drone and you before pressing RTH.try 100 meters.....if i remember right minimum distance is 40-50 meters...i could be wrong,its long time since i played with RTH.......one more thing.always do Flat Trim and Calib ration before every take off
heti
