Error motors (11)
Collieman
Bought a second hand Parrot bebop 2 and I have the error message (11) on screen…………..I've tried to change rotor (frontleft) but I still have all motors in red on my screen!! Any help…..anyone can confirm that all 4 rotos are dead?
Thanks folks
Did you try reset,turn on bebop2,wait 30 seconds then press and hold power button for 15 seconds,release power button and wait till bebop2 goes trough reset procedure,connect to freeflightpro and see if anything changed
Hi, Thanks a lot but yes I did try many reset without results…..:-(
Do you think that it's because the drone didn't fly for more than 2years ….?
Its possible,..all you can do is take everything apart and follow power cables from motors all way down to main board,very painfull to do it,takes lots of time...if all motor cables are connected properly than you might have bad board ....if you think its board you can replace it
Prinesan chetty
