How to manually land & turn off Anafi Drone
Pretty Parrot
I am new to the Anafi. Yesterday when it was landing on short grass it bounced & would not turn off. I will get a landing pad for such times, but how do you manually land & physically turn off the drone should a similar incident occur. I can't find it in the manual.
Hold "down" the Left Joystick. that will force it down. It may pause if it senses something underneath but if you hold it, it will land/shut off.
That being said, the grass is not the best to land on because the props are so close to the ground and the fan on the bottom of the Anafi is exposed.
It will land nicely on your palm! Again, if you hold the Joystick "down" and hold your fully open palm under it
Reactions: Pretty Parrot
lustar
