Is my anafi dead?
MrWayne
My anafi crashed from a heigh of 7 feet and after that when I try to start the drone I just can see the green lights and listen the cooling fan. No beeping... the gimbal doesn´t calibrate... Freeflight doesn´t find the drone.
I tried with the battery reset, drone reset, reinstalling the app... and nothing.
I hope nobody had the same experience but if someone know about it and what I can do, I´ll appreciate it.
If it is no fault of your own then firstly contact your supplier as the Anafi is faulty and if you get no joy then contact Parrot.
If there is no major external damage, then it may be possible a connector has come loose inside the Anafi. The following video gives you some idea about the connectors (and what you are in for with regards to repairing). A link to a disassembly manual can also be found here.
