Multiple connection issues with FFP 5.2.7 and Bebop2
Hi,
I´m currently running into a huge problem. I have an Bebop 2 which I´m trying to connect to my Skycontroller 2 via FFP ver.5.2.7(installed as the guide in the forum provides). Still, I can connect the Bebop directly to the phone via WIFI just fine, but as soon as I´m plugging my Skycontroller into the connected phone it disconnects me from the drone and wont reconnect, even though I´m still logged into the drones WIFI. I even bought a second Skycontroller (2P) and it´s still the same problem.
Is there something I´m overlooking?
I have FFP version 5.2.4 which is for iOS Apple products. I don’t connect to Bebop 2 with iPhone. I first connect skycontroller 2 to iPhone with cable. Then turn on SC2 first, it will open FFP. Then turn on Bb 2. SC 2 will connect to Bb 2.
I tried Apple, didn´t work for me, so now I´m back to my Android phones. I tried the steps you discribes, but the skycontroller just keeps on blinking red and wont connect to the drone, with or without phone attatched. I´m not even able to select the drone in the app to connect it, as while the controller is plugged in, the app doesnt recognises any drones.
Hum, maybe the Bebop 2 is not broadcasting the Wi-Fi, so it may need a reboot. Hold the power button for 10-15 seconds and then wait for 1-3 minutes. Then try again. The Bebop 2 will loose the Wi-Fi password so you’ll have to reenter it. Good luck.
Awaiting moderator to approve a message on this thread. But would like to understand what could cause my phone to be able to connect to the SC2 or the Bebop2 individually but not at the same time. When I connect the SC2 to my phone via USB, Freeflight disconnects from the drone.
Hate to ask this again. I've tried everything to get a Samsung S25 to work with the Bebop 2 and Skycontroller 2 (Not 2P) together. I brought the package out of the closet where it has been for a few years, I've done the manual app install on the Android (5.2.7) copied folder into obb folder. Firmware on both devices are latest from what I can tell. I have set the wifi on drone to 2.4ghz using FFPro. There is no option to perform any wifi settings on the controller.
I've had only one time where everything worked together. No idea how, then drone battery died, and since then zip.
I can connect to the drone via wifi from phone app and control the drone, once I connect the controller to phone via cable it disconnects from drone, connects to controller. Once I disconnect the controller from phone it connects to drone again.
I have tried various methods of connection steps. Drone first, controller first, power one first then other, flip order and still not connecting together. Deleted FFP from phone, installed from scratch again as per other post. No change.
Reset drone via power button method, reset controller via battery removal/wait/connect. No change.
Any other suggestions before I take it all to the dump?
As I told you you shouldn't give up yet!, we could be very close to figuring out the issue yet no dump required/if it comes to it if you pay for shipping to me and back I will try my best to fix the sc2 for you!
HongMunoz
