Newbie Bebop 2 Connection Question
Pbober
Hello all! I am so glad I found this forum as it has helped me a ton. So, I have been flying my Bebop 2 trying to get some distance in. At around 80 meters high, I start to have connection issues. I am flying in a heavy residential area, so I am assuming there is just a ton of wifi interference. However as I lose connection and it returns home, I am having an almost impossible time reconnecting. So I have a couple questions. Are there any tips and tricks to get some more altitude without losing connection? Next, an tips or tricks to reconnect while in flight? Thanks!
do you have wifi off and airplane mode on , on your phone/tablet? I believe in the most recent firmware update when the bebop 2 goes into return to home you can't reconnect until it has returned.
I do...and the RTH has worked...but I can't reconnect for a good 5 minutes after it returns.
I have only used RTH a couple of times so I'm no expert. Are you landing and still not able to connect?
How about turning it off and back on again?
What is your connection mode?
Phone or Skycontoller 1 or 2?
Do you have both GPS confirmations?
eidbrainstorm
