no video on freeflight when using skycontroller
Phil W
Can anyone help with this issue, I have an original bebop parrot, it was working fine the last time I used it a couple of years ago, recently I got it out again to use and discovered that it has a video communication issue, when used with the skycontroller a message comes up on the freeflight screen saying update drone to display video, there is no video on the app, but when I turn off the sky controller and reset the drone the video works on the freeflight app, drone firmware is 4.0.6 and the skycontroller is 1.4.6, appreciate any help, thanks
i had same
Hi i had the same problem and solved it by updating the skycontroller firmware to 1.7.4 have a look at
Skycontroller Firmware Update
i downloaded the nap_update.pif file at the bottom of thread. put it on a fat32 usb stick anplug in to sky controller & switch on to update
kralendorf
