Parrot Anafi USA GOV Edition - Firmware
If you are using a Parrot Anafi USA Gov edition, please update your firmware with the instructions below.
Anafi USA GOV Offline Update via .apk
What’s needed
Download the Update
Update the System
  1. Power on the SCUSA
  2. Navigate to the home screen of the tablet
  3. Uninstall the Freeflight 6 version found on the tablet
    1. Press and hold on the Freeflight 6 icon till the options pop up
    2. Select uninstall
  1. Plug the SCUSA into the computer using the USB-C port on the back of the SCUSA
  1. Place the Controller in Connection mode.
  1. Ensure Anafi USA GOV is off!
  1. Press and Hold the Return To Home Button (keep holding)
  1. Press the reset button the on the back of the SCUSA near the USB-C port (you will need a pin for this)
  1. Wait for the LED above the screen to turn green
  1. Release the RTH Button
  1. A notification should pop up on the screen of the SCUSA to allow it to be accessed by the computer. Select ok
  1. Now the SCUSA is connected it should come up as the “Galaxy Tab A (8.0”, 2019)”
  1. Now open the file Titled “Download”
  1. Place the “FreeFlight6-release.apk” file in download folder
  1. Unplug the SCUSA from the computer
  1. Once it restarts navigate to the home screen of the tablet
  1. Swipe up from the bottom of the screen to see all the apps
  1. Search for the “download” folder
  1. Open the download section under “internal storage” on the left side of the screen and you will see the “Freeflight6-release.apk” (if it is not there wait a few minutes and it will appear)
  1. Open the file by pressing on it, then select install
  1. Once the new FF6 app is installed it will ask to open
  1. Open FF6
  2. Power on the aircraft
  1. In FF6 At the top of the screen press on the controller & Aircraft icons and install the updates
Check Updates
  1. Now power on the Anafi USA GOV (Power on the SCUSA if not already on)
  1. The System should connect automatically
  1. If not connected, follow the connections steps found in the user guide
  1. Wi-Fi pairing: P18
  1. Ensure the System is updated to the correct version
  1. FF6: 6.9.0 RC27 (open My.parrot in FF6 and software version is found on the bottom left of the screen)
  1. Aircraft: 1.9.4 (Open the aircraft icon at the top of FF6 - software version found on right hand side)
  1. SCUSA: 3.1.3 (Open the controller icon at the top of FF6 - software version found on right hand side)
Spencer Burrows
