Parrot bebop '1.5'/ 'power' mod.
Giannis K
Hey there peeps! been modding parrot drones for a while, I have an upcoming Bebop 2 'rescue drone' that I picked up for 30 euros with at minimum a frame replacement needed. Prior to that I had owned 2 other bebops 2s (1 fell in the sea due to chinese prop exploding, 2 motherboard was spontaneously bricked beyond repair) and 2 bebop 1s, the one I am modding now and another I tried to mod but with less tools and knowledge it was shoddy and went down the drain kinda. As I will use the bebop 2 for the main drone (big battery upgrade and some firmware tweaks to support the hero 10 I will hang from it) I am left with a bebop I wont use. Well, today I found myself bored. Stripped it down, removed and replaced with custom parts everything I could to keep the weight down and add rigidity (rubber things are gone) and there we go, Without battery 249 gram bebop 1! Used 3d printed legs, struts instead of the rubber things that I welded to the frame, and little c clips to hold the antenna wires, Here it is! and all the parts I removed :P, battery and battery strap add another 89 grams, so 338 grams total! 82 grams saved from the official weight!, around 18-19% for the statistics folks :P, The other mod failed because I went way to extreme with the weight loss and removed more stuff such as the internal frame supports,the drone's hood, half the magnesium back plane off the motherboard, made a new camera mount ect. A lot more scuffed, this should be actually usable and perform really well! Rest of the weight was from the removal of battery plastics, smaller parts and slightly smaller battery.
IMG_20250204_003320.jpgIMG_20250204_003330.jpgIMG_20250204_003336.jpgIMG_20250204_003515.jpg
Reactions: instalmedic
We shall soon be off for a test flight! I made a custom 1500mAh battery from some 30A discharge cells I had around and made a custom script on the drone's firmware that activates 'fpv mode', after 5 short presses of the power button it disables stabilization and filtering algorithms and streams at a lower resolution, with lower latency and at 60 fps! Code is:
#! /bin/sh # This script restarts dragon prog with FPV friendly camera settings
# Red LED for 2 seconds
(BLDC_Test_Bench G 1 0 0 >/dev/null; sleep 3; BLDC_Test_Bench G 0 1 0 >/dev/null) &
kill 9 `ps | grep dragon | grep '/' | awk '{print $1}'`
/usr/bin/dragon_prog -c 1280x3072 -s 1024x600 -V 120 -S 0 -I off -b 3500 -f 60&
¡Hola, gente! Llevo un tiempo modificando drones Parrot. Tengo un Bebop 2 "de rescate" que pronto saldrá al mercado y que compré por 30 euros, aunque al menos necesitaría cambiarle la estructura. Antes de eso, tuve otros dos Bebop 2 (uno se cayó al mar por la explosión de una hélice china, y dos placas base se bloquearon sin posibilidad de reparación) y dos Bebop 1: el que estoy modificando ahora y otro que intenté modificar, pero con menos herramientas y conocimientos, era de mala calidad y se fue al garete. Como usaré el Bebop 2 como dron principal (una gran mejora de batería y algunos ajustes de firmware para que sea compatible con la Hero 10, de la que me colgaré), me quedo con un Bebop que no usaré. Bueno, hoy me he aburrido. Lo desmonté, quité y reemplacé con piezas personalizadas todo lo que pude para mantener el peso bajo y agregar rigidez (las cosas de goma se han ido) y ahí lo tenemos, ¡Bebop 1 de 249 gramos sin batería! Usé patas impresas en 3D, puntales en lugar de las cosas de goma que soldé al marco y pequeños clips en C para sujetar los cables de la antena. ¡Aquí está! y todas las partes que quité :PAG, la batería y la correa de la batería agregan otros 89 gramos, ¡así que 338 gramos en total! ¡82 gramos ahorrados del peso oficial!, alrededor del 18-19% para la gente de las estadísticas :PAG, la otra modificación falló porque fui demasiado extremo con la pérdida de peso y quité más cosas como los soportes del marco interno, el parasol del dron, la mitad del plano posterior de magnesio de la placa base, hice un nuevo soporte para la cámara, etc. Mucho más rayado, ¡esto debería ser realmente utilizable y funcionar muy bien! El resto del peso fue por la eliminación de los plásticos de la batería, piezas más pequeñas y una batería ligeramente más pequeña.
View attachment 6492View attachment 6493View attachment 6494View attachment 6495
haven't been able to get the Free Fly Pro app to work to operate a Parrot Bebot 2. Since I installed the app, it shows a connection error, and all I can find is information that it's no longer supported. How can I fly Midrón now? Can you guide me on how to use it with real-time video as if I were using Free Fly Pro?
HongMunoz
