Parrot Bebop 2 Follow me error
ZotyAdry
Hi!
Parrot Bebop 2 I bought the follow me add-on.
A few times she went nicely and then she wasn't good anymore.
Everything else works!
If someone can help you write!
Thanks in advance!
Video
Reactions: Levy501
Hi!
Thanks in advance!
Video : Video Follow me error
Have you tried using a different device? Maybe it’s because your device has some GPS malfunctions
Yes, I tried several phones, but not good. (Huawei p20 lite)
Can Bebop be bad?
There is a brand new gps module. I also tried, but not good!
Sad :-( 27 EUR garbage (follow me)
Thanks for the reply!:ROFLMAO::ROFLMAO:
Can Bebop be bad?
The solution is FreeFlight Pro 5.2.1. !!
Mine did the same thing, it just didn't like my phones gps for follow me. It was fine for all other functions, but follow me rejected it, same error youre showing. It's a fairly new phone too.
I see that we all are having the same problem with the follow me part of the app. Parrot needs to really fix this issue because that's one of the reasons I got that the drone. And if it is our phones then that also needs to be addressed to the PARROT CORPORATION...We Need Our Bebop 2 To Work Completely Not Partially..
Hi!
Thanks in advance!
Video
I've had these exact same issues, so every time I'm at the park nothing...I went to the beach on Thursday 3-14-2019 I'm in Calif. I was showing some random guy the FOLLOW ME and to my surprise it actually worked and I was over the top with joy.
Reactions: ZotyAdry
Hi!
Thanks in advance!
Video
when you get to this screen just tap onto the red square until it changes to green
Hi!
Thanks in advance!
Video
when this happens just press onto the red square until it turns green
all you have to do is every time that screen pops up just tap onto it until it come on...follow me solved
seow
