- Joined
- Mar 15, 2019
- Messages
- 28
- Reaction score
- 4
Can you buy a spare battery for the Anafi 'Sky Controller 3'? I have searched the web but can't find anything about the battery. Neither on the Parrot site.
Thank you Landbo. I don't know why they didn't let you buy & use a back up battery. Every camera I buy, in fact everything with a battery in it I always buy a back up. Yesterday I set everything up waiting to take a video of a train & the Pilot battery failed. I thought there was more than enough to fly the drone. Had I been able to replace the battery, I would have been OK. I don't like charging partly charged batteries all the time as it's not good for them. Unfortunately as the drone is fairly new to me, I didn't want to use the 'phone only', to fly it until I am used to it.
Thanks for the reply. I do have a power bank, & normally I charge every time I fly the drone. However it would be nice to be able to put in new batteries should the need arise.The battery in the SkyController 3 is very difficult to replace, read almost impossible. But you can buy a 5-10,000 MA powerbank and plug that in the USB-C plug on the controller while flying. The power bank will then keep the controller alive even if the controller simultaneously charges your phone.
However, do not be afraid to charge the controller fully up after you have flown as a Li-Ion battery not in the same manner as a Li-Po is damaged by having full voltage (4.2 Volt).
And personally, I always charge the batteries and controllers fully up before go flying.
