Post ANAFI Crash Behaviour
andrewpholmes
My drone collided with a tall tree and fell. Inspecting the drone physically there are no signs of defects however I am getting some strange erratic in-flight behavior. The most consistent behavior is the drone spinning counter clockwise on decent. Can anyone tell me where to start looking ? The rotors are all spinning but I was wondering if there was a diagnostic tool of some sort to measure output or functionality of the primary flight components.
Andrew
Fully reset drone
Check 4 leg motor clips didnt pop open or break
With drone off, open bottom shell panel check all plugs are secure including motor plugs
calibrate drone
Format SD card
new props install
lightly check to make sure prop screws are tight
Check battery not damaged
Spinning could mean motor plastic screw housing clips are busted inside.
First couple of batteries dont let it get far from you or too high. 6 feet high and maybe only 30 feet away.
Without touching controls. Let it sit in one spot to see if it spins by itself.
Spin it right left, check yaws right left check rise and lower ability.
Check everything is ok.
Ammar
