Sky Controller not Find Anafi
Hi guys , anyone can help me ?
my sky controller not find my Anafi , I only can use Anafi with my smartphone .
anyone with this problem?
That happens to me before every flight, unplug cable from phone to controller when nothing is happening, then reconnect back to phone. This resets the startup mode. When fly tab turns green, press and you’re good to go.
This should get you going.
Paul
To bind the Skycontroller to the Anafi you can try this.
1. Turn on the Controller.
2. Turn on the Anafi
3. Plug the USB-C cable from the controller to the battery of the Anafi. You will see the battery lights flash from green to red and back to green again. You controller is now bond to the Anafi.
Reboot everything and it should work just fine.
Hope this helps.
Reactions: jmbsmt63
Have you had a look at the user guide and followed instructions for doing hard resets on both controller and Anafi?
Great idea except that there are no instructions for resetting the controller.
Connect phone to controller,freeflight 6 will open,hit controller icon in upper right hand side corner,hit Reset
Hope this helps.
Hi guys
I had the same issues for days driving me crazy, and this worked !
Try connecting via câble the drone and the SC3
Light will Turn Green then Blue, connect SC to Phone and should be good
stefante
