SkyContoller 2P Battery Connector
SkyFly
Does anyone know what battery connector is used to connect the internal cylindrical battery to the Skycontroller 2P?
This is the upgraded Skycontroller 2P with the black stick controls. It ships with the Bebop 2 Power and recently with the Bebop 2 FPV.
I need to purchase some.
Thanks.
Thanks.
Hello Skyfly,
I agree with the others, give Christopher a call he has what you need.
Skydreamer guided me to his website recently, glad he did tons of informative info on this website. I didn’t order from his site and instead made my own parts needed for SC2P cylinder battery mod, went with two 18650 3000 mAh 3.7 volt batteries Parallel to reduce battery drainage. Just did it today, so haven’t experienced the outcome from the mod.
The batteries are from eBay, with two chargers and 8 Li-Lon batteries was only $12-13 bucks. Also, picked up several of the 1S Lipo battery holders. Total for everything was around $20 bucks, can make several packs from these.
The battery connectors are off old sets of drone batteries had on hand, so i lucked out didn’t need to search the internet for the connectors.
Good luck, keep us posted.
Paul
Reactions: SkyFly
Hello Paul,
Your mod is lookin' good! I suspect you should get 8+ hours of flying before you need to recharge the batteries. Nice job.
I emailed Christopher a couple of days ago with a question regarding the battery telemetry. He told me that the battery usage IS displayed in FreeFlightPro when connecting the positive and negative battery leads to the controller. He has a YouTube video verifying this. There is no need to connect the 3rd wire. Apparently, the blue wire (3rd wire) is not needed for the telemetry function. The only other thing I could think that this wire would be used for is the BMS part of the battery charging system.
So far the original battery pack from Parrot seems to be working fine in my SkyController, but if and when it fails I am going to do this mod. I plan on modifying the SkyController to allow charging without removing the batteries. It will be a little tricky but should not be too difficult. I'll do some bench testing before I actually mod the SkyController.
I know there are a lot of guys out there sending their Bebop 2's back to Parrot because of the battery problem with the SkyController 2P. In some cases, Parrot is sending them the old SkyController 2 as a replacement. I would much rather have the newer version SkyContoller. This problem is actually working to our benefit. The 18650 batteries are way cheaper than the battery pack provided by Parrot and the mod is simple. We are no longer dependent on Parrot for a proprietary battery pack. If we could (I feel eventually we will) work out a battery mod for the drone itself, we would be in great shape. Maybe someone will use a 3d printer and come up with some kind of carriage or sliding tray that would fit the drone. I know there is one available for the Bebop 1. I'll wait and see. (someone with a 3d printer please jump on this).
Please let us know how your mod is working and what kind of flight time you are getting on your twin 18650's. Take care, thanks again!
Hello Paul,
Hello Skyfly,
Thank you it was an easy mod, yours will be just as good or even better. I have several Skycontroller 2 models, three are boosted with Solaris amplifiers one of them the SC2P. So battery usage will be lower even with two 1S 18650 3000 mAh batteries parallel compared to a stock SC2P with same battery mod. I do have a stock SC2P currently with one 1S 18650 Lipo Battery and it did well yesterday. But, I’m going to arrange a parallel setup like the boosted SC2P controller to extend flying usage. I’ll keep you posted how both do, haven’t really timed long long they will go before charging that I will do in the coming weeks ahead.
That third center wire is for charging purposes, I removed it and only use the two outer positive/negative wires. Will charge batteries outside of controller in the future, I’m ok with this.
Please keep us posted with your Battery mod, you made the right decision salaging the SC2P. Its auctually the better controller of all different versions, it has two lager panel antennas instead of four mini antennas. The two larger antennas have 100% more surface area versus the four mini antennas combined. Of the three Solaris boosted Skycontrollers I have, the boosted SC2P is the higher performing Skycontroller of the three. And, the easiest to modify with Solaris mods.
With the bebop 2 battery mod, you can disassemble an old bebop 2 battery and use the lower portion of battery for the battery tray. I started to do this until I tried a power battery, after purchasing a couple of power batteries and power charger boy what a difference with extended flights. Power batteries are great, they also don’t wear down as fast as stock batteries stock batteries tend to loose strength and eventually don’t last very long.
Good luck and keep us posted!
Paul
Thanks everyone for your input and advice. I am using the LiHV (power) batteries in the Bebop 2 with no problems so far. I also constructed a balanced charge cable and am able to charge them with a balanced charger. The charger provided by Parrot IS NOT a balanced charger. You will get better performance and battery life if you use a balanced charger. If you decide to go this route, there are a lot of charger choices out there. Before you buy, check out the reviews on the web. Just make sure it is capable of charging LiHV batteries. Fly high and safe.
Later....
Does anybody know the name and type of the 3 pin connector on the skycontroller 2p battery.
cheers Darren
Reactions: Waldo Pepper
cheers Darren
Hello ,
Don’t know the name size/type connector on the 2p battery, but if you’re wanting to replace this Battery you can cut off the connector from the 2p defective battery and use the two outer positive/negative wires. The middle wire you don’t need, just the two outer wires.
Good luck,
Paul
cheers Darren
It looks like a 3 pin JST?????modders won't want you to know because they are selling them.😉
No I think it is a 3 pin mini Molex. They come in different wire gauges as well. I will get my vernier out and order some.😉
Molex 51103 3-pin
and pretty hard to find. Be easier to snip it out and do your own thing.
stefaz72
