Skycontroller 3 is always trying to pair with anafi even when it's off
danielaves018
Hello,
My Skycontroller 3 is always trying to pair with anafi even when it's off. The dark and light blue lights are always blinking.
Do you know what is this problem?
Thanks in advance
I think that you have a faulty switch. It is situated near to the hinge point of the arm on the left hand side and can just be seen when the arm is opened. You could try pushing the switch down with some cardboard and see whether it turns off. Otherwise you can open up the controller, if it is out of warranty, using the propeller screwdriver and have a look if a wire has come loose.
Reactions: Mr.F
I assume that you mean that a wire had come off the switch. The switch on the controller works in reverse of what you would expect in that it makes the contacts to turn the controller off so a disconnected wire makes it stay on, which I suppose is the safest outcome.
gregholmes2696
