SkyController not connecting to Drone
bongi69
Hi All,
So since Friday I've had an issue whereby my controller will not connect to the drone.
I flew it at a wedding to get a group shot, came in to land and left the drone powered on for about 10 mins (sky controller was also on) while I got other shots before I was able to pack it up. Before I powered it off I still had a connection.
I went to use it today but the sky controller will not connect to the drone. The light on the controller & drone just flash as if waiting for connection.
So far I have done all of the below to no avail:
- Hard reset of the drone
- Tried different batteries.
- Tried connecting the USB C cable from the controller directly to the drone (the controller LED will flash green a few times when doing this)
- Reset the controller
- Once reset I tried to pair the controller to the drone. The drone will show as available, when you click on it to connect it will ask for the wifi password & successfully accept it but then will just say "connecting" and doesn't connect.
Connecting my phone to the drone using the drones wifi AP works fine and I am able to pilot & see the camera footage, but the sky controller will just not connect no matter what I try.
I've lodged a ticket with Parrot but in the mean time can anyone think of anything I can try to try restore connection, as I need to use it again on a job this week.
Thanks!
Go into the FF6 app with the controller connected to your phone/tablet. The controller icon upper right should be lit. Tap on it and get into the Skycontroller 3 page.
Look at the options: connect/calibration/reset.
Go through these three selections with Anafi powered and it should get the controller and drone talking to each other.
laviencosmetics
