Usb Port skycontroller
creazionivideo
good morning to all, someone would know how to tell me where to buy the card with the usb-a port for the skycontroller 3, parrot does not answer me, I live in Italy, thanks
As far as I know it is not available as a spare part. If the USB-A connector has come loose then others have tried with some success to resolder it to the board. If you are not confident doing this then I suggest that you find an electrical repair shop local to where you are.
Thanks but Is very damaged, Is impossibile to repair, parrot?
Did you try glueing it?? that is very messy!!
Someone with reasonable soldering skills should be able to fix it for you - it is not hard.
the only thing I can do is buy a used skycontroller 3 and keep it as a spare, I didn't think parrot was so unavailable
Maxence dlh
