Bebop 2 (fpv version) and FCC
Nolan
Hi all,
i'm using my Parrot Bebop 2 FPV, with SkyController 2. in Europe (on CE frequencies)
It has a bad cover (about 200 meter max) and I lost fastly the signal.
There is a way to set FCC mode and reach a greater distance without losing signal?
Thanks in advance
Fake GPS Tutorial
Try this,it works with anafi and freeflight 6,it should work with bebop 2 and skycontroller 2/freeflight pro.......note :skycontroller 2 doesnt have 5ghz signal,only 2.4ghz...if you follow this tutorial,choose usa location and once you go to freeflight pro network setting choose 2.4ghz Manual,channel 6....
Reactions: Nolan
Hi all,
Thanks in advance
Hi
Did you finally succeed?
