Data Request: Parrot Bebop Pro Thermal Survey Imagery
Saijin_Naib
Hey all,
I'm working to try and get OpenDroneMap to properly support the Thermal imagery from the Parrot Bebop Pro Thermal.
What do I need?
I need a sample dataset of at least 10 images collected in a Survey Flight Plan of some sort (grid, cross-grid, etc), so that we can try to reconstruct the data and make sure that we can properly handle the imagery, naming convention, band orders, data format, etc.
So, this would be a link to your dataset containing the JPG/DNG/TIFFs from your sUAS and your permission that we can use them for the purpose outlined above.
What do you get?
If you don't use any free/open-source software that relies upon OpenDroneMap, then likely nothing other than my most sincere thanks and the satisfaction of knowing that you made a critical contribution to the greater FOSS Photogrammetry community by providing much-needed sample data.
If you do use things like OpenDroneMap, you gain (eventually!) the ability to process your Thermal imagery into useful data such as point clouds, DEMs, and 3D models!
What does this support mean?
It means we go from having completely broken support for the Parrot Bebop Pro Thermal data, to perfectly usable and correct reconstructions from this data!
Call for data from OpenDroneMap Community:
