Data Request: Parrot Disco Survey Imagery
Saijin_Naib
Hey all,
I'm working to try and get OpenSFM to support the various Parrot hemispherical camera modules, like what are employed on the Bebop, Bebop 2, and Disco, so that photogrammetry suites such as OpenDroneMap can properly stitch the imagery into accurate point clouds.
With the help of the OpenDroneMap community and the OpenSFM developers, I'm already underway with getting Bebop 2 support merged into OpenSFM.
What do I need?
I need a sample dataset of at least 10 images collected in a Survey Flight Plan of some sort (grid, cross-grid, etc), so that we can try to reconstruct the data and make sure the manual Lens Calibration parameters that are derived are correct for that sensor.
So, this would be a link to your dataset containing the JPG/DNG/TIFFs from your sUAS and your permission that we can use them for the purpose outlined above.
What do you get?
If you don't use any free/open-source software that relies upon OpenSFM, then likely nothing other than my most sincere thanks and the satisfaction of knowing that you made a critical contribution to the greater FOSS Photogrammetry community by providing much-needed sample data.
If you do use things like OpenDroneMap, you gain (eventually!) the ability to process your imagery into useful data such as point clouds, DEMs, and 3D models!
What does this support mean?
It means we go from having completely broken reconstructions:
To perfectly usable and correct reconstructions!:
(Yes, these are the same data showing the same scenes)
Hi Saijin_Naib,
It would be great to see the Parrot Disco being supported by OpenSFM!
I would like to help and give you some samples.
Some questions:
Do you have any prefered camera settings such as RAW or JPG?
Camera pointed straight down?
Greetings,
Arjan
Reactions: Saijin_Naib
Hi Saijin_Naib,
Some questions:
Greetings,
Arjan
Arjan,
Thanks so much!
Hmm... I think for now as close to stock/straight-out-of-camera as possible. If you have both RAW+JPEG, great, if not, JPEG is fine!
Whatever the normal/stock camera angle is (if there is such a thing).
Miesher
