Parrot ANAFI SD CARD PROBLEM
Indy
Hallo,
I really need your help or tell me how to solve this problem.
Somehow lost original Parrot Anafi original sd card. Now replacing with other not-original sd, drone does not finds any of them! I can still fly etc but no options to use sd card! Maybe someone can send original sd card boot files or I don't know - any other options how to make drone be useful?? Maybe there is a possibility to buy a brand new original Parrot Anafi sd card?
Thanks for help!
Hi Indy
How many GB is the SD card you are trying to use? Anafi will only recognize cards that have been formatted to FAT32 file system, so you may need to reformat it on PC.
In FF6 does it show "No SD Card"?
If not are you able to reformat card in drone
Has your drone sustained any crashes or falls
Have you tried to perform a hard reset of drone
Yes, it shows “no SD Card”! Correct! I have not tried hard reset! Im not sure about crashes..
You're not sure of crashes is this because you bought it used?
Has the Anafi's card reader ever worked for you?
Sometimes a crash or fall will cause a loose connection of SD reader ribbon to motherboard
I would start with trying hard reset of drone
sorry for late respond! A fiend of friend bring it to me and said no need for this anymore. Did not said anything about crash! Ok. I will start with hard reset. How much would cost to buy new sd reader or/and motherboard if needed and where to buy?
Randallt14
