Anafi battery tester ?
Fmaxii
Rennes - France
As it seems not possible to have a real live reading of anafi battery with FF6 (this % is not reliable...), does a battery tester usable to test our barreries ?
we can see lots of battery tester for many kinds of batteries, even for bebop2, an adapter cable exists to connect the bebop battery to a charger/tester, but for now, i’m not able to find something for our barreries.
Have seen something to test them?
I have just charged my 3 batteries and mesured the voltage.
Batt 1 is 8.17v
Batt 2 is 8.56v
Batt 3 is 8.61v
I don’t know what i must think about that...
Are those voltages measured fresh off the charger after the LEDs indicated a full charge or after they have been resting for a while. If you put them into the Anafi and power it on what % battery does FF6 report?
I must do the same with my batteries when I get chance.
It was mesured 10 minutes after being disconnected from the charger.
I’ll test which % will be seen on FF6 today, in few hours.
Batt 1: 8.18v. FF6: 100% during 3 seconds, then 99%
Batt 2: 8.53v. FF6: 96%, stable value.
Batt 3: 8.58v. FF6: 97% during 3 seconds, then 96%
It’s hard to explain the relation between the voltage and the %....
And also hard to say which battery is better than an other one...
Am I the only one, who does see that already as a problem?
I remember, that FF6 did tell every charge different numbers, also for the capacity
I never looked at this before.
it’s a problem anyway.
The possibility to have an anafi battery tester would be appreciate...
Because for now, the multimeter seems to be the only tool we can use to have an idea of the quality of the batteries
I don't think the state of the battery is determined by the full charge, but by the 40-50% charge. Here, batteries in different states show a much larger difference.
Immerse to max (43%). and measure it here. It should be 3,700V at 44% -43%.
In fact, you would have to immerse yourself in 2-3% to really come out your weakness ...
And these measurements, on top of being unloaded, don’t really show the condition. The voltage drop is much steeper than a weak battery ...
The solution could be:
Others information from my batteries:
Batt 1: 8.18v. FF6: 100%, with max capacity indicated in FF6: 53%
Batt 2: 8.53v. FF6: 96%, max capacity: 96%
Batt 3: 8.58v. FF6: 97%, max capacity: 97%
It looks like my battery 1 isn’t in good health...
In flight? Because it's really only interesting under load ...
No, it’s not in flight.
The max capacity will not change during flight. This value is visible on FF6 where you can see the numbers of flight of anafi, the total flight time, etc..
With this 53%, i understand that my battery 1 is half used....
ok i did a measurement just for you.
I own 2 batteries A 28 cycles B 38 cycles
Battery A 100% 8.94V
50% 7.92V
40% 7.58V
Battery B 100% 8.90V
50% 7.88V
40% 7.54V
Hope it helps i don't drain them lower than 30% because i get my work in 40 minutes with both batteries if i have longer flights and lower stats i will post you the volts.
Those 100% voltages appear very high. LiHv batteries should not be charged at more than 4.35v/cell so a maximum for 2S batteries of 8.7v. Did you actually measure the voltage with a multimeter or take the figures from @AnafiPilot1 modified FF6?
Maybe my multimeter (made in China) is bad i will borrow a professional and i will post again.
Just measured it on a simple lipo multimeter the A battery charge it half an hour ago gives me 8.77V
PiperPilot1
