Thanks.The arms only come with the motors - you cannot remove the motors as the arms are glued / welded assembly.
Thanks. So are you sure that everything else, electronics etc. is the same? Sorry for the insistence, but I find this difference so 'petty', I can't imagine why Parrot made it.Buy the arm kit for your Parrot ANAFI drone - Official Website
Lists the contents of the pack. This is the one I purchased for my first revision Anafi to swap to the stronger legs.
Just a heads up, I modified another Anafi with the FPV/Thermal legs, recently - and had to go through 4 sets of these motors (bought from Amazon uk) as each time the rear left leg had problems.
Problems which caused that leg to vibrate more than the others, any way after 4 goes finally got an set where all the legs where good.
Are you going to tell me that you set up 3 sets to detect these vibrations?Just a heads up, I modified another Anafi with the FPV/Thermal legs, recently - and had to go through 4 sets of these motors (bought from Amazon uk) as each time the rear left leg had problems.
