Anafi thermal photo msx
Hi, im using anafi thermal.
I need to convert msx photos to visible and thermal.
To do this I use exiftool, but I noticed something strange.
I have two parrots (different firmware version) in one I get
3264x2448 RGB resolution and 296x222 thermal resolution
In the other one rgb with the same resolution but the thermal is 310x234
Is the resolution defined by the firmware?
And why is the resolution not 160x120 like the camera’s thermal sensor?
I think scaling the original thermal resolution to double will give you approximately the resolution you wrote.
The difference between the two resolutions is 14 pixels both horizontally and vertically. Because the difference between the two machines in the firmware this may be the reason as well.
veloviento
