battery flashing red
ketrab
After the crash the battery started to flashing red. Tried to do hard rest but still the same. Any thoughts before declaring it a loss?!
Hard to say what might be wrong with it. So you have tried all of these resets with no luck?
Here is the hard reset procedure for ANAFI.
1. Power ANAFI on.
2. Press the power button and keep it pressed: after approximately 8 seconds, the battery's LEDs turn on red, one after the other.
3. When the 4 LEDs are red, release the power button.
4. ANAFI reboots - a TXT file has been generated on ANAFI's microSD card, which contains ANAFI's Wi-Fi network's password; that's how you can check the hard reset has been successful.
To do all 3 reset..
3) Connect phone to controller and it should open up freeflight 6, once the controller and the drone have connected, hit the Drone icon to the left of the SD card icon, in the next screen you will see map and numbers below map...scroll down and you will see a hidden Factory (soft) Reset button...reset anafi and right after you will be asked to recalibrate ....if that doesnt happen automatically then go to settings/camera and attempt to recalibrate from there..
1. Power ANAFI on.
To do all 3 reset..
You can't do a hard reset since the battery won't power up the device so #2 from Skydreamer is faulty logic.
After hard reset of the battery #1 it still flashing red. Without opening the enclosure I don't think there is anything else we can do.... :(
Sadly I suspect failed battery - I have seen this once on one of the batteries that got wet, and the cells failed.
coadyread
