Hard to say what might be wrong with it. So you have tried all of these resets with no luck?
Here is the hard reset procedure for ANAFI.
1. Power ANAFI on.
To do all 3 reset..
2) Reinstall the battery in the Anafi, power up, then press and hold power button for 12 seconds to do a hard reset.
3) Connect phone to controller and it should open up freeflight 6, once the controller and the drone have connected, hit the Drone icon to the left of the SD card icon, in the next screen you will see map and numbers below map...scroll down and you will see a hidden Factory (soft) Reset button...reset anafi and right after you will be asked to recalibrate ....if that doesnt happen automatically then go to settings/camera and attempt to recalibrate from there..
