Battery Issue
optoron
Hi All ,
Normally a Disco flyer but owing to a recent crash , needed a new camera . Managed to source a Bebop 3.0 in full working order but 3 dead lipos. I manufactured a mini tamiya convertor ( dremel cut the end off the lipo ) and hooked up a brand new 1800 3s 15c lipo from Hobbyking and took it for a few spins before I cannibalised the camera . Its capable of quite nice footage and with skycontroller é there doesnt seem to be a range problem .
However Im only getting about 8 or 9 mins till low battery warning . But when I hook it up to a lipo voltage tester it says each cell is still sitting at 3.9v and when I subsequently balance charge it , it takes about 900 mA to charge it full again . Thinking it may be a battery fault I hooked up my 2700mA disco lipo . Again get about 10 mins before low voltage warning . Voltage tester again shows 3.9v approx and again takes about 1200 to fill the battery again .
Anyone know whats happening . Could the voltage table be corrupt . Could it be my homemade tamiya connector ( which is basically the wires bulked out with thick copper wire and jammed into an xt60 female hole ) is not allowing the full voltage to be read correctly . I have a proper tamiya convertor on the way , and yes I know to reverse the polarity
I eagerly wait on sage advice
Hi All ,
The battery you use is not large either. In a Bebop 2 the battery is 2700 mAh so what you are using now contains only 2/3 of the power of an original. At the same time you cannot count on a 15c lipo can supply enough power to a Bebop. I'd guess you need a 40c or 60c battery to get your Bebop flying normally. Remember to buy an Li-Po by weight & c when choosing your battery, not the cheapest. ;)
Regards Leif.
HongMunoz
