Bebop 2 Wont power on
rps911
Hi guys,
After one or two flights, the Bebop wouldn't turn off unless I removed the battery.
Now, with three fresh, fully charged batteries, the Bebop 2 won't power on.
I've open it up and checked if connects are there, and they are.
I've tried the reset trick holding power button for longer than 10 seconds also.
Reactions: jdiggs2191
Hi,you could have bad main board,no fix for that....there are main boards on ebay for sale for less than 100$.... there is one thing you can check,power button has small board behind square white plastic,board has 2 buttons,so when you press power button make sure you press right in center of white plastic piece....you can expose power button board by removing 3 small screws and making sure power board is properly connectedto Main board(reinstall and install again)
Thanks a lot mate!! I checked it out..., no go. Strangest of things and it’s practically brand new out of the box.
