Camera black lines on sides
Swordfish
Hello guys
when im in sportmode recording video i get black lines appearing on the outer edges of the screen. However this only happens when the camera is facing forward, when facing downward the black lines dont appear. Anyone had this problem or know what the issue is?
A picture would illuminate the problem but I'm guessing you're seeing the props. The de-fishing makes them look like video artifacts.
Hello
Thanks for answer, but it happend on the upper portion of the camera when pitching forward also, not only on the sides. If i get the drone with mi hand with propellers off and i do the movement by hand (pitchforward movment) then appears those lines.
Thanks and sorry for mi english
OK then, you're seeing a rectangular frame that is stabilized and processed from a wide angle fish eye lens. When you point the camera down, the image processor is working with the top of the fish eye image and so you're seeing a black border which is the limit of the lens. It's normal.
Deleted b/c in the wrong drone forum , sry!
stefaz72
