Camera not tilting
Sgt rock
Hi all I'm running freeflight pro on my bebop 2, for some reason the camera has stopped tilting it won't move up or down, I use flight controller 2, I'm assuming it's a software problem as the actual camera is fixed isn't it?
Any help greatly appreciated
Thx
So when you say it's a fixed camera, can you change the focus of the camera from straight ahead to down toward the ground? I've never messed around with the angle of the camera focus.
I did a reset and followed the video but now freeflight won't connect I get an.! Next to the WiFi on my phone lol
That is normal, the ! means the wifi connection has no internet. Look at the wifi connection, it should say "Bebop2" plus a bunch of numbers.
Go into your app manager and clear out data for freeflight pro. Or you can uninstall and re-install the app.
You can change the camera angle with the left scroll on the skycontroller 2 . You can't change the focus, just the angle. It works well for a fixed lens camera.
I used to be able to tilt the camera using the sky controller 2 it doesn't focus or zoom just tilts ?
