Crashed Anafi
Oakwoodflier
Hi
First time on here
Long story short I clipped a tree and fell onto rocks.
Battery smashed
Proppellers damaged
No other apparent damage
Today I have unfolded the drone and the front right leg is a little loose and has not got that significant click when opening out.
There is 2-3mm play
I obviously do not want to fly to see if its a problem.
My question is can I disassemble the body and somehow retension the spring or whatever it is that clicks it out. Thanks for your help on this matter
Not the best video but I think you'll get the idea
Hi Dirk
I had looked at this earlier.
It does reference the hinge.
My problem is the rear right is perfect and clicks when closing.
Whereas the front right does neither.
I would have thought if hinge was damaged then both would not click, unless I'm missing something.
I will dismantle in the meantime anyway to see if there is any obvious damage.
Thank you for your rapid response.
Cheers Simon
Hi former:)
Sold out.. and do not know when next In stock.. if ever
Have now seen photo of hinge shaft and understand how it works.
Not very technical minded🤔
I've tracked down some used shafts on ebay🤞Thanks for your advice
Simon
msyarbrough
