Dron ANAFI
VictorVilla
Drone, Anafi, muestra el mensaje "Cámara vertical defectuosa. Póngase en contacto con el servicio de atención al cliente de Parrot". No vuela, la cámara se mueve, si toma fotos, se puede calibrar, pero el dron no vuela. Actualización reciente a la versión 1.8.0, el hardware es HW_03, el mensaje apareció después de la actualización, previo funcionaba bien
Drone, Anafi, shows the message Camera Vertical defective. Contact Parrot customer service. It does not fly, the camera does move if it takes pictures, it can be calibrated, but the drone does not fly. Recently update to version 1.8.0 the hardware is HW_03, the message appeared after the update, previous it worked fine
Search for "Vertical Camera" and you will find some more information e.g.
I get the same message. I have read a lot of these threads and it seams like a software problem but I crashed my Anafi. I replaced the broken arm. everything works fine except that it will not take off due to the "Vertical Camera" Fault. I am not sure if the sensor is bad?
HongMunoz
