Drone stopped working with 11% battery and crashed
Another thing is: there is a different if you load the battery slow or fast: If the charging slow, the battery doesn't heat up and the energy in the battery is higher as via fast charge and higher temperature. The battery of the Anafi is full, if all 4 LEDs are off and not if the charger reported that the battery is full.
There is a charge circuit in between, which the charger didn't know and can not calculate The same thing is on the Lipo from the Disco. One battery was defekt. After disassemble the battery it shows, that the charging board was broken. I put the board out, add on the Lipo a new Balancerpflug and charge now this battery (without anythings in between) on my normal Charger for Lipos.
Gesendet von meinem viennalte mit Tapatalk
tipe
