no problem of cap weight , gimbal structure are not correct.
C chawongyun Member Joined Dec 24, 2018 Messages 19 Reaction score 1 Dec 24, 2018 #1 no problem of cap weight , gimbal structure are not correct.
Dirk_ANAFI Well-known member Joined Aug 7, 2018 Messages 1,177 Reaction score 475 Location NRW, Germany Dec 25, 2018 #2 That's well known! The cap (or a filter) touches the gimbal frame and initialization fails.
Kilrah Well-known member Joined Sep 22, 2018 Messages 239 Reaction score 99 Dec 25, 2018 #3 You just need to remove the cap before powering on...
C chawongyun Member Joined Dec 24, 2018 Messages 19 Reaction score 1 Dec 25, 2018 #4 Kilrah said: You just need to remove the cap before powering on... Click to expand... Some of anafi can be initialized without remove the cap. Do you know why? ㅠ.ㅠ
Kilrah Well-known member Joined Sep 22, 2018 Messages 239 Reaction score 99 Dec 25, 2018 #5 The tolerance at the end is close and may vary between units? Cap may be slightly different or not put on the same? Why is that a problem anyway?
M mrajic Well-known member Joined Dec 23, 2018 Messages 96 Reaction score 86 Location Chicago Dec 25, 2018 #6 When I take the cap off I have problem with the initialization. When I forget to take the cap off it becomes a nightmare to boot my Anafi back again.
