Frequency Range | Power Output | Rule Parts | Grant Notes | App # |
2.412-2.462 GHz
![]() | 227 mW | 15C | CC, MO | 2.1 |
5.18-5.24 GHz ![]() | 166 mW | 15E | CC, MO | 1.1 |
5.745-5.825 GHz ![]() | 407 mW | 15E | CC, MO | 1.2 |
I think, the US thing was a test, they measured the output under FCC settings
And the CE thing is the max power, in a area without any interferences.
In Holland , how wifi infected is the area, you are trying to fly?
It is not just your HP spot, also the area, the bird is flying too is in question.
Still wifi needs a slot, when others arent using the same channel (in 2.4 GHz the next 2 channels down/up are interfering with your channel).
I have experienced better connections/distances with the weaker (power output) 5 GHz band, in urban areas at least.
Even in Singapore (my avatar), where the marina bay area is overloaded with wifis, I could fly the Anafi in (assumingly) CE mode about 300m away, before it got fragile.
I'd maybes factor in the cost to buy that against how much you'd get selling your Anafi and adding $250 to the sale price I'm sure you would get a drone which wouldn't even need a signal booster.
Because the skycontroller point is as far away from the drone as the drone is from the skycontroller, the performance should be the same. This is a two-way data communication.Wow that is a big difference between Ce and FCC. Now i can understand the range between 200meters and 1,6km
the only questions is this the wifi power on both site or only the skycontroller.
If it is only the sky controller than i'm good with 2w sunhans ampiflier
Operating Frequency | 2.412-2.462 GHz; 5.745-5.825 GHz |
Max Transmission Distance | 2.412 - 2.462 GHz (unobstructed, free of interference) FCC: 1.2 mi (2 km); CE: 0.3 mi (500 m) SRRC: 0.3 mi (500 m); MIC: 0.3 mi (500 m) 5.745 - 5.825 GHz (unobstructed, free of interference) FCC: 1.2 mi (2 km); CE: 0.18 mi (300 m) SRRC: 0.7 mi (1.2 km); MIC: - |
Operating Temperature Range | 32° to 104° F (0° to 40° C) |
Battery | 2970 mAh |
Transmitter Power (EIRP) | 2.4 GHz FCC: ≤26 dBm; CE: ≤18 dBm; SRCC: ≤18 dBm; MIC: ≤18 dBm 5.8 GHz FCC: ≤28 dBm; CE: ≤14 dBm; SRCC: ≤26 dBm; MIC: - |
Operating Frequency | 2.400 - 2.483 GHz; 5.725 - 5.850 GHz |
Max Transmission Distance (unobstructed, free of interference) | 2.400 - 2.483 GHz; 5.725 - 5.850 GHz FCC: 8000 m CE: 5000 m SRRC: 5000 m MIC: 5000 m |
Operating Temperature Range | 0℃ - 40℃ |
Transmission Power (EIRP) | 2.400 - 2.483 GHz FCC: ≤26 dBm CE: ≤20 dBm SRRC: ≤20 dBm MIC: ≤20 dBm 5.725-5.850 GHz FCC: ≤26 dBm CE: ≤14 dBm SRRC: ≤26 dBm |
I live in a urban area with 4000 houses with wifi. with fcc i can 1.6km away from my backyard.this was on the 2.4ghz
now it is 200 meters and on 5.8ghz it is 250 meters.
Now i'm looking for external boosters and antenne. My eye is falling on this DJI - EvoLite Kit (Phantom 4 Pro / Phantom 4 Pro Plus / Phantom 4 Pro V2 / Phantom 4 Pro V2 Plus) by Maxxuav
I know it is making for dji but it must also working for the anafi and has 2w sunhans dualband boosters. and if it is working i paint it blackand than is the signal problem forever gone even when i buy a new brand drone.
