Seitenwerk
- Joined
- Dec 24, 2018
- Messages
- 195
- Reaction score
- 157
Great
now the only thing that’s left is to check how good the barometer actually works. That will be my next test
I'm glad that you offered to do that, I get vertigo!Greatnow the only thing that’s left is to check how good the barometer actually works. That will be my next test
I'll have to test that out, with walking or running in a long straight line before going under that shelter. I suspect it does as I have seen video of the Anafi following cars through forests & it just kept on going at the same pace as the vehicle.Oh and watching your video (first few minute) i wondered: Would the Anafi maybe also take your velocity into account when switching to or using the gps? Like when you walk or even run and it is flying at the same speed then you run under the roof you used in the first minutes of the video, would it „estimate“ that you may come out on the other side and try to catch you there? I have seen some footage of people driving behind a tree and the Anafi kept going into the same direction like it would expect its target to keeping the current direction and speed even if it lost visual contact.
Ye, I'm hoping to borrow a device with a Barometer to test skiing. Will probably be looking for a new phone before long, Pixel 3 or Huawei Mate 20 Pro if I need one with a Barometer sensor. Look forward to the results.Not yet, will try that out as soon as possible. Btw I am using a device with a barometer, so I can only test this case
I'm still at a complete loss as to how you get it to lock onto a car. There's no option for that anywhere in Freeflight 6 that I can find!If you have a barometer in your device this works very well. There are limits as to how fast it will change in altitude. If you are going to fast the Anafi might not have enough time to adjust. Some devices work better then others.
Thanks! You are the second person to tell me that today! I'll be trying it tomorrow morning... Fingers crossed...Should be enough to draw a rectangle or double tap on the car
Not to my knowledge, it needs a target to lock on to so as to initialise the Follow Me mode tracking.Can I use my Anafy in follow me mode WITHOUT selecting and watching myself like the Yuneec drones, so it follows me and the Skycontroller let say about 200 meters behind me over the river? Sorry, maybe I missed this in the instructions and threads!!!!
I'm curious how does a Yuneec drone follow you without selecting a target?That's too bad.
Tracking a car/vehicle/bicycle with the Anafi is very easy because you can basically use just a phone to control it and put the phone on the seat or in a bracket/pouch and then select the car/bicycle,etc and go..I'm still at a complete loss as to how you get it to lock onto a car. There's no option for that anywhere in Freeflight 6 that I can find!
As mentioned above, if your device has a barometer then the Anafi will follow your altitude very well!Anyone had a chance to try this feature while changing altitude? (With or without a barometer sensor in their device) I'm going skiing next week and am looking to give it a try off piste, would be good if the Anafi could change altitude as I'm descending down some of the mountain.
